And the core-only will not flatten out on the drum (desirable) like the cover-only will. Keeping shape is desirable over blocks, which is one more reason why core-only make sense for halyards and sheets... but that is NOT what we are talking about. This is the ONLY application on the boat that requires winding on a drum.
I'm certain on some very large boats there may be strength concerns, but not until sheet loads are well over 3000 pounds (when the sail is deployed there is a lot on the drum and the leverage is good).
You are really over-thinking a non-problem. Pull the core, taper, lock-stich, clove hitch to the drum (with stopper knot) if the hole is inaccessible. I'd be done in 10 minutes (I've done this a number if times).
