I've been fighting outboard difficulties ever since I got my boat..was going to bite the bullet and buy a new one after doing all the "simple" maintenance (it had no water pump impeller left when I got it, so it obviously has been overheated) because I didnt really want to go through a full rebuild on a 30 yr old 2-stroke. Carb rebuilt, gearcase oil changed, new water pump, plug wires, fuel buld and filter...it got better and better but it still just loses power over time, then shuts off. I did a little experiment yesterday...set it at a high idle, in gear, tied to the dock. I thought my experiment was going to fail, it ran for 30 minute or so before the rpms started slowly decreasing...ripping the cover off it was like the poor motor just screamed THANK YOU and it revved right back up to a bit higher than where it was. I dont really want to pull the gaskets off between the case and the motor (it tends to get wet in waves more than about 2') Any clever ideas for an intake from the outside, with water drain or something?It's an 82 mercury 180cc.
