Maine Sail ... I have used your "process" in the past and am happy with the results but am now a little confused about the subsequent years .....
In your detailed outline you wrote.....
[I]The Process:
Buffing and waxing a boat the right way takes time and is a commitment. On a gelcoat hull of 36 feet I would plan on about 5 hours for doing a two step polish, & wax or about 6-8 hours for a two-step glaze & wax. This is once you get caught up, after your first re-condition, including a wet sanding or compounding, it's usually only a two step process each spring. Unfortunately, the first season of re-conditioning may take you up to 20 hours if your hull is heavily oxidized. It's a commitment but gives a beautiful finish.[/I]
Last year I put on 2 coats of the Collonite wax. Late November the boat was hauled and covered and stored over the winter. This spring, after removing the cover I washed the boat and it looked pretty good and the water still beaded suggesting that the Collonite was still there. Then I worked the polish/wax steps and it looks good but not as good as originally and I wondered about the prior layers of the Collonite wax.
So my question is this ..... Should previous years applications of wax be removed before starting the annual polish/wax process? If yes whats the best way to remove that wax? Mineral spirits? Acetone? Denurtured Alcohol?
Would appreciate your insights.
Thanks
James
[I]The Process:
Thanks
James
