Not a difficult subject ................
...... but for peace of mind, you may want to get THE book on mechanical maintenance by Nigel Caulder (forget the exact title and mine's on the boat but any marine supplier will know it). An excellent book.This will give you an insight as to how a stuffing box works and how best to maintain it. The gland (as it is also known) may require re packing and this is something which you MAY be able to do in the water. Again, Caulder's bible is the source for this material. If you do repack, see if you can locate teflon impregnated flax for packing. I have used the same packing for two years and I get away WITHOUT LETTING IT DRIP. I know, I know ........ I'm crazy, but the shaft runs ice cold, it still has a mirror finish on the wear surface and my bilge is powder dry.Hope this helps.Regards,sv Island Hunter
