stuffing box trouble
robert
I am having trouble undoing the locking nut on the stuffing box. It seems almost welded to the other nut. Any suggestions.
Brian Leney
One approach which works....
Taught to me by a boat mechanic: use a ball-peen (sp?) hammer on the locknut (ball-peen hammers have a round ball head in place of the claw found on typical hammers in case you are not familiar). Works for me everytime on my boat and have used technique on other boats as well. Using the ball end of the hammer head, GENTLY tap on a crown of the locknut, in the direction it needs to turn. At first I used to be concerned about damaging the locknut using this approach, but it hasn't caused any harm after all the times I've done it on my own stuffing box. The shock of the hammer blow is enough to break the corrosion "weld." Simple, quick and works everytime.
Randy Jarrell
The nuts are "welded" due to corrosion. Use a stainless steel brush to clean the nuts and they will loosen easily.
Terry Cox, P42, Belle-Vie
We had the same problem with ours...,
I squirted some Liquid wrench around the lock nut, lightly tapped it on the flats with a hammer, squirted it again and let it set for an hour. Broke right loose. Repeat if necessary. Terry
Tim McCarty
I used a big 'ole pipe wrench...
and some WD40. If all else fails. I keep the pipe wrench on board for extra ballast when I need it (sorry...couldn't resist). Good luck...
