Leaky box
Marcia, have you attempted to first of all tighten the packing by turning the stuffing boxes 2 large nuts? You will need 2 macho size wrenches. I used large crescent wrenches, they sell special wrenches but I didn't find them especially helpful. As Ed says the packing size is boat specific, and depends on shaft size. I found it EZ to do but it depends on access and the skill level is owner specific. See if you can tighten it first, if that is too difficult you will not be able to handle changing it without help. After you adjust you need to motor a bit and then make sure the stuffing box is not getting hot to the touch. That's why they drip, to stay cool. If it is hot back off the adjustment. If things do not improve easily you'll need to change the packing. Make sure your bilge pump is working correctly before doing anything else. Since my prop shaft is 1 inch and my pushpit tubing is 1 inch I wrapped my GFO packing around the pushpit tubing and cut it to size so it was ready to install as soon as stuffing box was opened and old material removed. My stuffing box actually stopped dripping entirely when I took it apart and did not leak at all as I changed the packing. Mine has a 1 inch shaft and 3/16th" packing. I used GFO. No leaks now, no worries.Good luck, and wear a life preserver. (/kidding)
