Packing Size,etc.
Rich;The size is correctly stated by Bill W.;It is the difference between the shaft and the inside lip of the packing nut.On the 1" shaft of my 34 that would be 3/16"......same for any 1" box.I also would use Teflon packing as opposed to the older flax(wax) packing[costs a little more-but worth it].Less likely to score the shaft if over tightened.You can get away with no drips using Teflon...but normal is 2-3 drips per minute.After running my engine for 3-4 minutes in gear at the dock, I feel the stuffing box...if it is hot you are too tight.Hope that helps?Cheers-CaptHawks/v RogueWave
