Drip-less
I replaced the flax on my H33 this Spring. I bought what I think you are referring to as "drip-free", purchased at West Marine. It was easy to use, by first removing the old flax with a tool made for removing the packing. If you buy one, it is the small version. You also have to buy flax since it is not supplied with the "drip-free" material. Cut two rings, measuring by wrapping and then cutting on the bias. Test fit the ring, making sure the cut isn't too long or too short by wrapping around the shaft. Install the first ring into the nut, then follow the instructions on packing in the "drip-free" putty. It is like a soft clay material, and will build up between the inner ring of flax and the outer ring. When installed, tighten the nut to hand-tight, then an extra 1/4 to 1/2 turn with the wrench. Start the engine and put in gear (make sure your dock lines are good and tight of course). Observe the suffing box for any leaks. With this stuff, there should not be any drips, or very few while the shaft is turning. After running for a while, shut the engine down and touch the stuffing box. It should be warm to the touch, but not so hot that you can't touch it. Re-adjust the nut if necessary. Be very careful while the engine is running! Do not get your hands anywhere that they can get caught.On the subject of doing this while still in the water: I have never tried that, but have talked with several sailors that have. They say that it isn't too difficult to do, but make sure you have sponges and rags at the ready, as well as a working bildge pump and a fully charged battery.My great fear is that doing all of this on the H33 means that you are stuffed in that small opening, practically standing on your head to do this job, and that means that it takes time to get in and out while doing the job. It would be a safe idea to have another person on board in case of an emergency. Otherwise, I would hold off until the next time the boat is hauled out. You might be able to put off the replacement by just tightening the nut now until it stops leaking. It should not leak at all if the shaft is not turning. A few drops a minute while the shaft is turning is the norm.Good luck.Ken, S/V Liberty
