Steve G.
I just replaced my suffing box (nasty job getting the old coupling off). Anyhow, it appears the former owner had only one ring of packing material installed in the packing nut. That didn't seem right, so I layed in two rings (all that would fit in the nut) of 1/4" packing (that seems to be what had been there). I left a 1/8" gap in each ring and offset them 180 deg. I greased them w/packing lubricant also. The nut proved almost impossible to put on, so much that my palm and wrist were aching from trying to get it started. I wrenched it and it went all the way down (with a big 'ol wrench), but the shaft seems rather tight. The stuffing box tube torques a little as I turn the shaft in neutral.I was wondering:A) Is it just the cold weather in New England freezing the grease?B) Should I step down to 3/16" packing material?C) Will that resistance cause a heat problem with the shaft?I'd appreciate any advice,Thanks
