Just gotta say, I still do not understand why people think they need to do this on the hard.
The flax material, as is the whole stuffing box, is a lubricant. The lubricant is water.
When you do it on the hard, you have NO way of knowing how tight it needs to be. So you end up putting your boat back in the water with either a too loose or too tight setting. Too loose? Not a problem, just tighten it up. Too tight? Backing off does NOT let the material expand, so you've wasted a perfectly good repacking for nothing, and should do it all over again.
And, if done on the hard, once you put it in the water you start the engine right away to get away from the dock to your slip or mooring. Thus, little or no time for the water to get to the box to lubricate it.
I had our boat out for two months one time, and had to replace the material 'cuz it all dried out. How'd I know? I went out for a little motor and checked it.
For those of you hauling regularly, it would seem that you should do this regularly, too, like, every time you put your boat back in the water, while it is IN the water. Your boat will not sink.
