Steve
Does anyone know the correct assembly of a plastic Stuffing Box? I bought a 1992 H28 last fall and recently dropped the rudder and pulled the prop shaft so I could replace the cutlass bearing. The Stuffing Box has two plastic washers and one thinner metal washer. When I removed the old packing material, there were two layers (rings). After this long winter, I can't remember the order the parts go back together. Is the order Plastic washer, packing, plastic washer, packing then the metal washer or does the metal washer go in first? The way I have it together right now is: packing, plastic washer, packing, plastic washer, packing and the nut (I left the metal washer out). I tried to get three layers in but I don't think the nut is threading on enough to be safe. Is two layers OK?I am scheduled to launch on 21 April and am rushing to get everything done!Thanks to anyone who can help.
