Stuck
515
Hunter 320 Williamsburg
removehtml]Hunter must have used 3M 5200 to seal the ignition panel to the pedestal of the H320. Any ideas how to remove it? Thanks. Error: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
Jun 1, 2005
772
Pearson 303 Robinhood, ME
If you can...
look at the backside of the paneal to see if there are any signs of how it is attached. Might see some screws or signs of adhesive. If it is adhesive, you might have to work at it with some sort of exacto knife. Or go on the Hunter forum... or call the dealer. Rich
Jun 4, 2004
125
Hunter 333 Elk Rapids, MI
use solvent
There is a solvent for 5200 that you spray on and let it sok in for awhile. I can't remeber the name but WM sells it.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
DeBond, we have it here.....
http://shop.sailboatowners.com/detail.htm?fno=400&group=1190 Dave Groshong Customer Service SailboatOwners.com
Mar 31, 2007
59
- - SF Bay
Try using a heat gun
Just about every plastic is a thermoplastic. Heat everything up evenly and slowly so the 5200 gets warm. You might be able to use a sharp chisel to pry the panel off. If the pedestal is metal this should be easy. Just get it hot around the ignition panel and keep the ignition panel covered and cool.
JungleJetJock
Dynamite
Dynamite. That is the only surefire way to remove 5200, and that only does about a 90% job.
Jun 4, 2004
273
Oday 25 Alameda
Appropriate Solvent, not heat
Buy the solvent here or at WM. It's not voodoo, it just works as intended. Apply at the edge of the bead and chase it in with a thin putty knife. Give it some time and keep encouraging it with the knife. Works fine.
