I am in the Philippines and I own a MacGregor 26 X (Hull No. 09521697) which I bought from a previous owner here in the Philippines. Firstly, I'd like to know if somebody, on the basis of its hull number, can give me the year it was built. Secondly, Its steering mechanism is stuck and perhaps somebody may be able to help solve the problem. Viewing it from the rear, the rod on the starboard side that protrudes from the tilt tube is stuck. I believe this should freely move in and out of the tilt tube as the wheel is turned to control the movements of the entire linkage and thus maneuver the 2 rudders and the 55 hp outboard between them in a synchronized manner. The rod at the opposite (port) side which is connected to the cable coming from the wheel seem to be detached from the stuck rod.
If anybody had the same problem previously, perhaps he can advise me on how to solve the problem. And should it require consultation from a servicing company and replacing some parts, I'd like to know where considering that the MacGregor company has evolved into Tattoo Yacht.
