My oil filter will not come off (Universal M18 engine). Does anyone have any suggestions? I already did the screwdiver as leverage, and attempted with a filter wrench. Should I chisel around the gasket?
I just bought some of those grip wrenches from WalMart that are advertized on TV. They have a black elastic band attached to a blue handle. I know the commericals on TV are rather cheezy but the wrenchs really work. I was amazed how well they worked in confined spaces. I used them on the Racor,fuel and oil filters. A piece of sandpaper underneath the band might really be great....Good luck
I got it off using a 1 inch wide metal sheetrock spatula around the sea,l and then working back and forth with a screwdriver jammed through the oil filter
Great! Now check the sealing surface carefully, and when installing the new filter (I guess you've done this already!) oil the seal and not too tight.jv
