So here goes my Oday 23 is a 1973 model. It has an iron trunk with retractable fiber glass keel. Do you know if the fiberglass keel contains any lead or heavy metal within the fiberglass? I do have the dinette post and was able to find the crank. However I have bigger problems now the keel is stuck in the trunk. The boat has been sitting on land since 1996 so the iron trunk has rusted away causing a layer of friction between the keel and the iron case. Also the hinge that the keel swings on might also be frozen. I tried every thing from clearing the gap between trunk and fiberglass. Drilling holes into fiberglass and pulling keel down, banging down on keel from inside boat however it wouldn’t move an inch. Has anyone experienced a similar problem like this? I feel like the boat is worthless and won’t sail well without the keel down, this is the only problem with the boat everything else is mint. I also thought of fiber glassing an extension to the keel and making a new one that was fixed. Has anyone ever tried jerry rigging a new keel onto a stuck keel? Any help on this matter will be greatly appreciated.-Stephen PaulWestbury, NY516-236-8026spaulhk@gmail.com
