Strut isn't lining up. Help!
456
Hunter 31 Seattle
If the rig is not tensioned (for example, if the the mast is off the boat you will need to reinstall and bring the shrouds/stays to the correct initial rig tension - 15% of break strength) please re check motor shaft alignment. There will be a slight change once final rig tension is established.
Charles
Good to know! Thanks for the input. If things are off I'll be sure to keep this in mind.
