TO continue the case on my excessive vibration that would not allow the engine to get to full RPM as reported by the previous owner I have finished the following;
1) Replacement of propeller shaft
2) Replacement of cutlass bearing
3) Installation of R&D flexible shaft coupling and alignment of the engine better than the .010 that was called out by the shaft coupling.
4) Rebalancing and re-build of max-prop.
After doing all this i look a look at where the shaft goes through the stern tube and it is way off - see pictures. What would you recommend? Should I 1) heat up the strut and use pipe wrenches to bend the strut until the location of the shaft is correct in the stern tube 2) Go through a major engine alignment to align the shaft in the stern tube 3) Do nothing as long as the engine alignment is correct.
Thank you as always
Thank you as always
