stripping cetol from teak
Jan 12, 2024
23
sabre sabre 30 jersey city
hi all , does anybody have the best technique for stripping that stuff? does it react to heat gun and scraper like varnish or is sand paper in my future. i plan to re-apply. youtube hasnt coughed up much on this subject
May 27, 2004
2,057
I'd like to hear an answer as well.
My concern is that Cetol has pigment in it that, like stain,
may not respond to the normal, heat gun and scraper techniques.
Likes: domer94
May 27, 2004
2,057
Thanks jssailem.
I saw this response on the thread you referenced:
Re: Removing Sikkens Cetol or HLS
I use Citris-Strip to remove Cetol from parts I can take off the boat. It's a gel and you leave it on for hours and let it work.....low rate of evaporation. Works great and probably does not cause brain tumors. Clean up with water.
I'll study up on the thread as the weather warms up! ;)
2,151
I have used "Te-Ka" for decades. Cleaner Kit - 1 Quart Each A & B | West Marine
I have a blog entry with some pix over on the Ericson owners site.
Sep 4, 2005
6
- - Sausalito
What? The entire reason I've used Cetol these many years is that you Never have to strip it off or do any sanding. Scrub it clean with some mild soap and a brush and then dash a few more coats on. Doesn't it say that right on the can?
CJE
Likes: captcoho
It is not a stain, just a vapor permeable coating with lots of solids in it which obscures the grain in the wood. The original Cetol had a very objectionable orange tint. The current flavors of Cetol are less objectionable.
The only advantage to Cetol is its permeability. It allows vapor and air locked in to the wood to pass through it which helps to prevent the finish from lifting off the wood. Polyurethanes and more traditional varnishes are not permeable, so water vapor and air in the wood will cause the finish to bubble and crack, allowing more moisture into the wood which causes more bubbling and cracking.
Using Cetol can provoke some strong sentiment about varnish devotees.
Likes: captcoho
Jan 13, 2009
394
J Boat 92 78 Sandusky
Bought a boat with a ton of teak. Previous owner had used Cetol and it hadn't been maintained. Used a Bahco carbide cabinet scraper and a heat gun. Definitely faster and more efficient than sanding. Used 1 step cleaner and brightener then Star Brite teak sealer. Matte natural finish. No film buildup.
MitchM
Jan 20, 2005
1,031
I have some Japanese cabinet scrapers, 3 straight blade and 2 curved blade, that were very handy for last year's project of removing old chipping and peeling cetol from my teak steering wheel. (which has taken a huge amount of time . wish I'd read this thread before then. )
Likes: LloydB
Jun 21, 2004
2,975
Beneteau 343 Slidell, LA
Cetol is the only finish that I have used that lasts for four years in Southern climate. I get no pleasure from annual renewal of varnish finishes.
Not necessarily.
Wood is damaged when water gets into the wood. End grain access is the usual issue. Screw holes and scratches also proved a path for water to get beneath the coating. On going inspection and maintenance is what prolongs your coating life and wood beauty.
Here are some tips and coating suggestions.
Does this mean that Cetol might make wood more susceptible to mildew than varnish would? My compression post would like to know.
No. Cetol is permeable not porous. A permeable membrane requires a pressure differential for vapor to pass through. That's how Gore-Tex works.
Non-permeable finishes, like varnish and latex paint do not allow any vapor to pass through. All wood contains air and moisture when it heats up in the sun, the air and moisture expands and tries to escape from the the wood. When it hits the finish it puts pressure on the finish which causes to begin to pull away, the finish will bubble. At night the wood cools and air and moisture are drawn back in. The repeated pressure changes eventually weakens the bond between the wood and finish and the finish cracks and fails.
Because Cetol is permeable, the vapor (not water) passes in and out with pressure changes. As a result it does not stress the bond between the finish and the wood. Because of the properties of water, water vapor is able to pass through while liquid water can not.
Jul 5, 2011
754
Oday 28 Madison, CT
Thanks jssailem.
No worries. All of us sailors have brain tumors or else we would not be in the sport
