stripped motor mount bolt
Jan 20, 2015
1
Hunter 336 Grove, OK
I have a 1995 Hunter 336. One of the lag bolts on the starboard front motor mount has stripped from the stringer. I need to know what is backing this bolt and how best to do this repair.
Thanks for your help.
Jan 21, 2009
260
Catalina 30 Lake Perry, KS
Don't know how the mounts on your boat are fastened. I had a similar problem with a 1986 Hunter. The engine bed was wood and the mounts were held by lag bolts. My repair was to remove the bolt, drilled out the hole to the size of a hard wood dowl . Loaded up the hole with epoxy and pounded the dowl into the hole. Let it cure completely and and screwed the lag bolt back. Worked great.
