Strip a lead keel....
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
One of my projects is to strip my lead keel and refare and paint. When I purchased the boat, the hull had just been blasted to remove all paint, however I think he painted right on the lead with no or minimal prep. I have many bare lead spots where the paint is flaking off.
1 - What is the best way to take it down to the lead... sanding or some sort of acid. Figure I would start the project soon while the boat yard is empty.
2 - then should I fare out with epoxy, then barier coat
Thanks all
Greg
Dec 2, 1999
15,184
Check out the Interlux/Yacht Paint website for specific instructions (of course it is specific for their products).
5,802
Just did that this past fall. And it was my own fault. When I bought the boat I took the bottom down to bare gelcoat and put on five coats of Interlux 2000E. Right, I should have done the keel. So I opted to let someone else take off the paint remembering too clearly all the work in 1999. I had the entire bottom soda blasted, best $600. I ever spent. After some fairing with West System I applied four coats of Interlux per Steve's recommendation above. Now she sits waiting for bottom paint in April.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
The problem with lead is :
1. It is toxic
2. It oxydizes almost immediately.
I used a belt sander and disc sander in an electric drill to strip mine, use a really good respirator so you don't inhale copper paint and lead dust. As soon as it is stripped, coat immediately with west system epoxy to seal it from oxydation. Put a second coat on to make sure you didn't miss any spots. Then use a barrier coat and put several coats of that, this makes a good base for paint adhesion. Next apply your paint, and then launch the boat.
