Hey....that test would be interesting to see. Make sure it is stamped as upvc plus find a cpvc they also come in gray. And depending manufacture come with different colored handles blue,yellow etc. besides red...Most upvc valves will have a octagonal shape to them and most are slightly off color. While the standard pvc will usually be totally rounded and are not stamped as such but just maybe have the size stamp on it.If you stick with "plastic" valves I would recommend the OEM 93 Series. Once you know your sizes any chandler that sells Forespar can order them. I've got some more testing to do so may just grab a white valve with red handle to see how it does....![]()
http://answers.yahoo.com/question/index?qid=20090525055147AA4UQ9H
Right now I am not happy with the way any of my thru hull fittings are attached at the hull. Nor am I satisfied that hull would not fail first before the thru hull fittings. Plus hunter located one fitting. The masacrator pump discharge in such a location that the only way to reach it is to climb on to the swim platform and open hatch exposing the chance that a wave hitting the back of boat just the right way while hanging up side down in side storage locker. Not to mention thru hull is exposed to any thing rolling lose in that space. That Thru hull will be removed and glassed over when I do the next haul out.
