Butch, your engine sounds seriously overpropped. If you look at the performance curves for the engine, unless it has an automotive type governor, its 26hp rating will be developed at maximum rpm 35-3600 rpm. If you follw the curve to the 2500 rpm mark you will see the power developed is considerably less. So while your engine is nominally 26 hp, the way it is currently set up it is only (say) 15hp. As it only takes about this amount of power to drive a boat the size of yours at hull speed in fair conditions, this won't be much of a problem. But when you are in a tight spot and you need all 26 horses, you will find they are not available. Only 15 hp plus black smoke. Other problems, well canvassed in this forum, also arise with overpropped engines.
