I have a factory installed refrigeration on H356. Wires from the DC panel to the refrig is 8 awg. I'm the process of installing a new compressor after the 10yr old died. Was checking the voltage and found I had a 1.6v drop from the panel to the install location 13.4v to 11.8. The line run appears to be about 17ft. Positive connections on both ends look good. Have to trace the ground side to check it. Very Strange drop.
Looking at installing a new power source directly from the batteries which are only 6ft, fused for 15amps and a new on/off switch push button.
Anyone have any ideas?
