Strange Electrical Voltage Drop
2,175
Hunter 356 Cobb Island, MD
I have a factory installed refrigeration on H356. Wires from the DC panel to the refrig is 8 awg. I'm the process of installing a new compressor after the 10yr old died. Was checking the voltage and found I had a 1.6v drop from the panel to the install location 13.4v to 11.8. The line run appears to be about 17ft. Positive connections on both ends look good. Have to trace the ground side to check it. Very Strange drop.
Looking at installing a new power source directly from the batteries which are only 6ft, fused for 15amps and a new on/off switch push button.
Anyone have any ideas?
11,772
Jim,
A 17' one way run, 34' round trip, with 8GA at 15A is a 2.74% volt drop at 12V. You likely have some termination or corrosion problems...
Apr 22, 2011
980
When you checked for voltage drop did you eliminate the negative side of the circuit? That is, touch the negative multimeter terminal directly to the negative battery lug. If the drop is being caused by a problem in the negative side, I would run a new negative wire directly to the battery negative bus. If the drop is in the positive side and you can't find the source of the resistance, a new direct run to the battery with a fuse and on/off switch would work or rewire the old positive wiring.
My PO installed an on/off switch that stays lit when it is on.... works for us.
Oct 14, 2005
2,191
Jim...
Try doing a resistance check on both the positive and negative wiring runs, moving from point to point of each connection and looking for resistance in each section. Suspect connector corrossion as did Maine Sail...
May 24, 2004
7,237
CC 30 South Florida
Sometimes it is easier to lay new wiring than to try and find the cause of the voltage drop in the old circuit. I like the idea of a shorter run as it allows for reduced wire gauge.
Mar 21, 2004
2,175
Good idea, checking the negative side. That will be an easy one since the negative terminal is about 4ft away. Will be on the boat this weekend and will check things out...
Dec 2, 2003
1,637
Measure both Pos feed drop and Neg return drop independently
Measure both positive feed drop and neg return drop independently.
With the unit running put the meter + lead on the battery positive lug and the meter - on the pos connection to the fridge. You may need to extend the meter leads.
Volt drop should read not more than 1/2 volt.
Then put meter + lead on negative connection to fridge and meter - on the negative battery lug.
Again this should not exceed 1/2 volt and the lower the better. (i.e. less than 5% of the supply voltage).
Both volt drop measurements should read about the same and if either is too high then your wiring is too light or your connections are bad.
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
Check for a 12v light bulb that may have power to it full time and is switched on by giving it ground. Also some of the new electronic bilge pump sensors may also get triggered the same way. ??
Jun 6, 2006
6,990
I'd be cautious installing new grounds directly to the batteries. This adds yet another connection to the battery terminals which gets cumbersome if the number is too high and the max number for a connection to the batts is 4 wires per terminal if memory serves. It also opens up the possibility for a ground loop which can lead to corrosion problems. Also, and of much lesser concern unless you have a ham/marine HF radio, is the running of power wires in anything other than parallel sets. The magnetic fields of parallel wires with current going in both directions (one out and one back) cancel. If you run them other than parallel you get pops and snaps as the unit cycles on and off. Also can effect the compass if the wire runs close by.
Mar 21, 2004
2,175
Got down to the boat today. First thing I did was remove and clean all connections. Reattached check the voltage, now only losing .1v for about a 30-34ft run.
Problem appears to be fixed
Thanks everyone.......
