Hello all-
We have a 1987 TRBS with a Universal M-25XP. We’re getting a faint, quick, intermittent buzzing sound from the engine panel in the cockpit which is similar to the buzzing when the key is on but before the engine is engaged, but this sound is much quieter. And (and this makes it strange to us) it happens when the engine is not running and the key is stowed. There is no regularity to when it happens. As I said, it’s a quick, quiet beep and it can happen six times in a 2 hour sail, twice in a 3 hour sail and not at all for a couple weeks! Has anyone experienced this? I called the factory and they suggested it could be that somewhere between the engine and panel there is a loose or dirty connection. I just figured I would see if anyone has experience with this before I pull things apart.
Thanks!
Jerry
Thanks!
Jerry
