Hi Everyone. Does anyone know the make/model of the single burner stove for a Catalina 275? I have the cutout (10-7/8" x 10-1/4") and the cutting boat but no stove! Thanks.
Thank you!The manual that I have for mine say Seaward Butane Stove Princess Model 1203-1004, 1203-1006.
I have not used mine in a couple of years. Last week I installed a new butane canister and tried to use the burner. It would light, but would not stay lite when I released the ignitor. Anyone have this problem and have a fix for it? Thanks.
I had that problem with it not staying lit. There is a flame sensor adjacent to the burner that allows the gas to flow when it heats up. It has a wire connected to it that had fallen off mine. I resoldered it back on which solved the issue. It's quite awkward to do without removing the stove, but removing the stove is also a big job.The manual that I have for mine say Seaward Butane Stove Princess Model 1203-1004, 1203-1006.
I hope you mean as a way to test if its the sensor! That sensor prevents dumping the butane directly into the air and with the wires connected, if the burner goes out you will be putting unburned fuel straight out of the nozzle and into the boat. Can't imagine your insurance company would think this is a good idea beyond the fact that its incredibly dangerous. Just my opinion though. Overriding a safety feature like this is pretty foolhardy unless its just for testing.Thank you. I checked all wire connections and all are secure. It seems the cause is likely a bad flame sensor. It's unlikely that I can find a replacement. I'll try removing the sensor and connecting the two terminals with a wire.
