Chris
The second reef is done the same as the first, through it\'s own
separate blocks etc. For two reefs I might bring them down on opposite
sides of the boom and back to opposite sides of the companion way, to
keep them well separate. The one issue I have with the way the boat
is rigged is that because everything comes back to the cockpit, and
everything meets at the mast bail first, it is possible for the line
I\'m working to grab a bight of a slack line and pull it into the
working sheave, jamming it. So I pay attention to slack lines. I will
fix that someday by re-aligning the lines and moving some off the mast
bail onto deck blocks. I am interested in what you have designed at
the mast step David. It sounds like a clean solution. I had thought
of adding another bail a bit higher on the mast, but haven\'t. Holes in
the coach roof are drilled out with a spade bit the size of the bolts
washer, the cavity filled with fortified resin, the bolt hole drilled
through that and backed up with a fender washer or aluminum plate. The
result is probably stronger than the original skin and foam core, and
mistakes can be fixed with resin and paint. Each line that comes
through the splash guard ( reefs, halyards, downhaul, cunningham ,boom
vang, topping lift) has it\'s own hole, ½" I think , reamed out a bit
with a rattail file, swabbed well with resin and painted. All in all,
I\'m well pleased with the setup.
Craig #1519 Tern
Craig #1519 Tern
