storm jib hunter 19
34
hunter 19 slaughter beach
hi I dont want to invest in roller furling yet but would like a smaller jib for heavier winds
any one have recommendations in size and where to shop?
Jun 16, 2010
495
In search of my next boat Palm Harbor, FL
You can always build a PVC furler. Search SBO and Google for it. I built mine for about $50. They work great for boats under about 23'.
-na -NA Anywhere USA
Adrian;
When you look at a cost of a small storm jib, compare the costs of roller furling as well. If it is not much more, then you may want to reconsider your options. Home made furlers may be option due to low cost but suggest you really research that route first.
If you go with a commercial furler, look into the small one by CDI which you can purchase thru the Hunter owners website.
Jun 16, 2010
495
I agree with Crazy Dave about the homemade furled, they aren't perfect. I have used the PVC furled for the past year, I do 90% of my sailing solo, so it works good. When it comes time to replace the foresail, I will also get a real furler for it. I replaced my main with this years tax return, so the foresail will have to wait till next year. Keep in mind that unless you go with a pvc type furler, you will need to have a different foresail, one meant to go with a furler.
My boat came with a jib, a 150% (which I put on a homemade furler), and a storm jib. The storm jib has never been out of the sail bag, and the p/o says he only used it a couple times.
Feb 29, 2012
13
oday mariner 2+2 aurora IL
What year is your hunter 19.
I'm looking for info on the 19-2 93'-96' is this the 19 you have?
