storing tools aboard
njl
May 30, 2011
64
Westsail 32 NYC
Do you do anything to prevent rust on tools stored aboard your boat?
Airtight container? oxygen absorber? silica gel? coating with mineral oil?
Ross
Jun 15, 2004
14,693
My boat is docked in fresh water and all of my hand tools are plated. Wrap your sensitive tools in rust inhibiting waxed paper and keep them covered.
Jun 26, 2011
22
Bruce Roberts R50 Ipswich
I have a dry boat so no rust problems... Ok no one is going to believe that. Truth is, I am always working on my boat so tools are covered in a film of engine oil and diesel. No need for further protection!
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
kloudie1 said:
Along those lines.. I have used Zerust drawer lining material, which is supposed to release a rust-inhibiting vapor to protect against rust and corrosion. It's great for lining the bottom of tool boxes, storage areas and drawers, is non-slip and easily cleaned. You can get either 12" or 22 1/2" wide rolls, 118 inches long at Lowes.. They claim that the rust inhibiting properties will last for up to 5 years. I also usually throw a few desiccant packets in my tool boxes just for good measure :)
Cheers,
Brad
Zaphro
Mar 20, 2008
101
Catalina 34 Mayport
When I was a Gunners Mate in the Navy, we used this on pretty much any metal that you didn't want to rust (including machine guns mounted externally exposed to salt spray). I continue to use it to this day. Wipe your tools down with this when you're done, and put them away. If you're going to leave them for a while, wrap them in a cotton cloth (used t-shirt) sprayed with it.
http://www.google.com/#q=breakfree+...gc.r_pw.&fp=30a5f43bfd918fef&biw=1280&bih=717
RichH
Feb 14, 2005
4,773
Boeshield T-9™ !!!!! ... a wax-like spray used on aircraft and its electrical systems to prevent corrosion.
Especially good for preventing 'micro-crystals' of salt from attacking the metal .... that 'grey film of dust' that covers every inch of an ocean going boat's insides.
Also good for electrical/electronics connections, and any other 'rustable' metal: tools, vee belt sheeves (when boat is laid-up), etc.
http://shop.sailboatowners.com/prod.php?12052
T9's great stuff. Throw away your WD 40 and get this and PB Blaster for all your household needs! :)
I also find USE helps keep 'em clean. I use mine a LOT! :) Tools, that is...
zeehag
Mar 26, 2009
3,198
pb blaster and a lubricant of choice.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I use an old military ammo container for my tools. It seems to have rubber grommet all the way around the edge of the lid which keeps moisture out. My guess is tht you can still buy these at surplus stores for a low price. Although heavy, It's a great container.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
As per MaranaF, my boat tools seem in constant use, so maybe my protectant is elbow grease ;)
I do sometimes remember to wipe the steel tools with a greasy rag, especially if the rag was oily for another reason (oil check, cleaning,etc)
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
you can get theses boxes on line from Casto trading co......just google it ...they useally have about 3 different sizes....and you can also tell them i sent you......only because i like for my positive connections to know who is talking about them ...no money in it for me what so ever....just friends helping friends.....
regards
woody
Mar 26, 2011
3,979
Corsair F-24 MK I Deale, MD
Two sets.
One small set of common things--a few screw drivers, pliers, common wrenches, adjustable, and vice grips--that stay in the cockpit, ready for minor battles. These see lots of salt and don't look to great, but last a few years anyway. And a good set that doesn't get put away with salt on them.
Like boats: ventilation. I use our nav station desk as my tool box. I use a kitchen divider to keep things separated. It gets opened a lot, the tools are handy, and I put 'em away clean.
