Peter - Da plane! Da plane! - Greg
Peter,I first picked up on this from an old field guide to sail boats. The last line under the Hunter 23 was “The 23 will plane”. Kinda like a warning Huh? The deal is, 23’s are really  light, overpowered, flat-bottomed boats (check the specs)Ready to experiment? If you’ve go enough wind in your aria (and I can’t imagine you don’t) then it’s easy. You don’t need a spinnaker given 18-25 knot winds. Below that I use a spanker but there’s a problem with that setup I’ll get into later.Given the right wind conditions, you can get up on plane if your pretty much flat. That means on a reach. The whole trick is to get enough of the hull out of the water to allow your boat to accelerate to planing speed.  You need a following sea. I think that’s what it’s called. The waves need to be going roughly in the same direction you are because you’re going to ride one up to speed. Set your course, set your sails perfectly (no reefing – you need the power), pick your wave and move everybody as far aft as possible which will bring the bow up a little.  As you crest the wave, move all forward to the hatch (did I mention you need a tiller extension?) and wait for it. If it worked, you should get a low freq hum from the hull and your knot meter will start to climb fast. After about 7.8-8.0 knots, you’re committed and you should be able to see and hear a roar, which is the bow wave just in front of your stubby little keel and in view between the cabin and the winch. Some where around here you’ll notice the boat really wants to broach, and I mean REALLY wants to broach. If you can keep it under control, you’ll continue to accelerate up to 10+ kts. With the broach under control (Ha!) you start to look for somebody to pass. After all you’re almost out of control, making all kinds of noise and  just about the fastest little cruiser around.If you think you’ve got a broach problem with the 110, you wont believe what you get into with a spanker. You can’t really understand the phrase “tiger by the tail” till you try it.Notes:Have the winch handle in the winch. You can’t do anything to the jib sheet by hand.If your jib sheet cleats are marginal use something else. If you jib blocks aren’t rated to a minimum of about 600 lbs. (mine are 2200 lbs) Don’t try this.All standing rigging should be in good shape (no bends)Go to the bathroom before you start.
