Anode?
It is mentioned a number of times in the archives, and elsewhere on the net, that the smell could be from the anode that has deteriorated and has part of the iron core exposed. I have had a sulphur smell from ONLY my hot water most seasons except for the last few. I ordered a new anode, but have never installed it. I have been more careful commissioning the water system in the past few years, and my water has been significantly better.
I just did some checking on the Seaward manuals, and it appears that to use one of the anodes, you need to remove the drain valve, and replace it with the anode (and NOT put the drain back in). If I read the instructions correctly, then this suggests that:
1) I still have my drain valve on my heater, so I must not have an anode installed, and thus, the anode could not have been part of my smell problem, and
2) if I do install the anode (maybe not needed because that couldn't have been the cause of the smell), then to drain the tank (which I do every fall), and would have to unscrew the anode and let water wash over everything as opposed to using the drain valve to let it drain through a hose to the bilge.
Can anyone confirm that my thinking is correct on this one?
Chris
