This past weekend I found a switch in the starboard lazarette that must be the pressurized water switch (turns on pressure water pump). Prior to turning this on, I had tried pumping the handle on the galley and head sinks - no water. I'm pretty sure there is a couple inches of water in the fresh water tank. 1) Why doesn't pumping bring water to the sink and 2) How do I use the pressure water capability? Is my problem that there is not enough water in the tank? How does 'pressure water' get pressurized - compress air in tank or actually pump water through hose?
cbourne200
cbourne200
