Dan Geltmacher
Still Leaking oil from the reversing gear linkage(I think).Facts as I know them: 1. Leaks when running and not running in gear and out. 2. I check the fluid level every time prior to start up. The level is below the line on the dip stick (measured unscrewed). There is oil in the hallow portion of the stick if you look inside. a small bubble. Not facts: I think it's coming from the linkage where it enters the housing. My shop manual shows a seal there.Does the engine need to come out to change that seal?Hawaii dan
