The last 2 times I've cranked up my Yanmar diesel, I heard a low screeching sound and found that the water pump pulley was not spinning in spite of the crankshaft pulley and water pump belt spinning. It was a quick fix, I easily (and very carefully) started the WP pulley spinning by giving it a qucik twist on the outside face (for safety) and it spun OK.
I have a Yanmar 2QM15 and I was wondering if anyone has seen this before? Maybe my belt's too loose? On the adjusting brackets, the WP is set as far back as possible, so i can't tighten the belt, or maybe I need to take it apart and check the inside.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
