Sticky Ridder
C
Chris
I have a 1986 C-22 that has developed a tight rudder board. I have taken the rudder off and can't figure out how to get it lubricated to get it to travel freely again. Any ideas?
Ken
Jun 1, 2004
1,182
Catalina 22 P. P. Y. C.
galling
Do you have the 3/8 gudgeons and pindles? I had to replace mine something got between them and caused them to gall. I replaced them with the new 1/2" C/D offers, they also have a delrin bushing. If you decide to make the swtich use two pieces of 1/4" all thread rods to hold the drilled bronze plate behind the top one. If you let it fall your in for a all day project.
A
Aldo
Could the Pintle Pins be bent?
Chris: Could one of the pins on your rudder be bent? I think that the pins on your rudder are bigger in diameter than those on mine. ut, if one is bent, this could make it bind. I lube mine with automotive grease stick that has teflon in it. I do think that the delrin bushed gudgeons are a good idea. I had thought of making something like this myself for years, but would now just purchase them instead. I guess you can still use your boat this time of year where you live. Aldo
