Hi all-
This is the head on my 1980 Catalina 30. It works fine and it fills a holding tank which pumps out easily enough. Standard setup I assume.
Pumping the handle is a little tricky as the motion is sticky and it's not uncommon that it leaks a little at the handle while pumping as well.
My question is:
Is this something which can be repaired by replacing the components of that pump? Or, alternatively is a new head required? It basically functions fine and does it's job it's just a little sticky, seems silly to replace the whole thing if there is something I can do.
I have no idea what model head it is so I've included a couple images.
Thanks!
-PrimeTime
My question is:
Thanks!
-PrimeTime
