My Beneteau First 38 nearly sank to the bottom of the marina last weekend!!!
After a few hours sailing around Galveston Bay, I pulled into my slip and tied down. When I went below deck to turn on the AC shore power switch, I noticed that water was starting to seep through the soles, and seconds after it started to cover them. I heard the sound of water gushing in from the engine compartment and saw it was coming from where the packing gland hose attached to the stern tube (the bilge pump could not keep up with the rate at which water was coming in). I immediately re attached the hose to the tube and stopped the water from coming in before any serious flooding occurred, and tightened the two hose clamps holding it in place.
I was able to drain the water quickly, dried everything up, and connected a dehumidifier that has kept everything dry.
Here's my question: is it possible that just 2 hose clamps are all that is keeping the hose in place and water from coming into the boat, or is something else wrong with the way that my stuffing box is installed?
After this experience, I will have a hard time relaxing when I take the boat out, so here's my second question: Is there anything I can do to minimize the risk that the hose will ever come off the stern tube ever again?
As always, the generous advice from more experienced boat owners will be immensely appreciated.
