stern rail?
5
hunter 23 Petenwell
I recently bought a Hunter 23 , Absolutely love the boat but The one thing it seems to be missing is a stern rail. Do they have one available or will I have to get one made. I need some place to put the grill.
Jan 2, 2013
74
Hunter 23.5 Lafayette, LA
I can send u some picks of what I made for my 23.5. I just bought a 26 yesterday and will make one for it.
Jan 2, 2013
74
This goes over the rudder area and has teak wood for a seat and a place for the pit. Very easy to make and no welding just two 30 degree brackets and two 90 degree tees then drill the holes thru the teak and rails.
Jun 28, 2009
312
hunter 23 Lake Hefner
Tee he has a '23 the transom is totally different than your '23.5. I've thought about getting a stern rail for my '23 haven't done it yet :doh: Brian_M_H23 has done the mod or his was bought like that. I think I remember reading that a catalina 22 stern rail was used on another.
Kermit
Jul 31, 2010
5,713
I bought this from West Marine and attached it to the transom. No stern rails or other modifications needed. Works pretty well for me. I'll be at the lake this weekend and will try to get a picture. In case I don't get the picture, the bracket is on the port side above the motor mount. I have no idea if this is necessary, but I always disconnect the fuel line from the motor when using the grill. A little safety never really hurt anything.
http://www.westmarine.com/webapp/wc...&subdeptNum=51158&classNum=51160#.Uhd3VD-DlIY
The picture shows the bracket mounted inside the boat. I mounted ours on the outside. I suppose either way would work, though.
We thought we wanted stern rails when we bought our 23 but have been happy without them. Nothing to get in the way of the tiller or motor or swim ladder.
Hope this helps.
Oct 3, 2006
1,029
Hunter 29.5 Toms River
I didn't make it, but here's a convenient photo I have, under full sail with a 3-strand nylon helmsman. It was pretty home-made looking: mounted to blocks of plastic that were through-bolted (single bolt) on big blobs of sealant to sit flat, the feet attached with 4 small screws each, and and the rail sat in the feet/ help by setscrews
As a side note, I just set the mast on the railing to trailer the boat. However, I think I had a tendancy to pull it down a wee too tight with the ratchet straps..the slight bend in the middle is my addition.
1,279
Hunter 23 Lake Wallenpaupack
My 23 has stern rails, one on either side (nothing across the transom). Came that way from PO. These are good quality stainless, with welded-on mounting brackets that are thru-bolted. No pics right now, but I assume he had these made by a pro.
-na -NA Anywhere USA
ask phil herring with this site if his store can make them for you. he certainly has come up with a lot of items no longer available which is amazing.
crazy dave condon
Jul 19, 2013
5
hunter 23 Petenwell
Thanks for all the info. If Hunter never made one I guess I'll find someone to bend it for me. I priced all the material through Wholesale marine and even with shipping its not to pricey. I'll post pics when I get it gone
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Made these for my 23.5.Got everything from Wholesale Marine.Your stern is probably diffrent,but can be done.1 trick,fill tubing with pool filter sand at tight bends,stops kinks.I bent a piece of 3/4 rigid first as a pattern
Hunter 26 Illinois
Ask Hunter
My 1995 H26 did not come with stern rail seats when I bought it in 2005. I called Hunter and though they did not stock them, they had the prints, so they made me a set. I would call them. If not immediately, perhaps they would make them when their tech is not busy.
