A remedy for you
Matt: Since we last conversed I have been hard at work to find the right fittings to make a yacht quality rail stiffener system available for your yacht. All yachts with a split stern rail encounter some troubles with fore and aft support for the rail on the yacht centerline. Davit systems can accentuate this force, given the leaverage they exert on the rail structure. I am now able to say that I have the fitting available and will be measuring a sistership tomorrow for the correct dimensions. The system will consist of a 75 degree rail stanchion base, a precut length of 1" tubing (same size as your rail), and a rail clamp that will fit your rail on either a vertical or a horizontal plane. It will install between the yacht's rail and the swim platform seat, and will offer the added advantage of providing a grab rail for people exiting the water from the swim ladder. This kit will allow the rail to place a compression load that will be carried directly into the deck, eliminating any rail flex whatever. The rail will essentially be only a "spreader" and accept none of the dinghy's weight whatever. I had some trouble with the concept of using flat bar as a reinforcing medium as it can (a) be bent off plane, and (b) does not fit in with the tubular structure - affecting the overall apearance. I think that this solution will solve the problem you are experiencing and improve the look and functionality of your system. Please contact me towards the end of this week or early next week. I should be able to give you an ETA by then - but it will not be long in coming. Thank you for airing this issue here, as rail reinforcement is a question that is frequently raised. I am sure others will have something to say here as well.
