Stern Rail for H23
Rich Phelps
I recently purchased a 1985 Hunter 23. I would like to install a stern rail. Does anyone know of a source (new or used)?
Brian Snook
Me , too.
I'd be interested in that information also (1986 H23). Brian
dave Johnson
stern rail
I just bought my Hunter 23.I also want to install a stern rail.I was told by the Sailboat shop in austin tx.That a cat.22 was close enough that it would esaly fit cost of rail was $380.00.I havent bought one yet still looking to find one used.Any help wite used parts would be apreceated.Hope this info. help,s
Dick Smith
Possible Source for Stern Rail for H23
Minneys Surplus Sails in Costa Mesa, CA has a lot of new Catalina 25 (I think) stern rails for less than $100. All include an end of boom traveler track and some had a car also. They ship, but you probably would want someone to look at one before you buy. Their URL is:http://www.minneysyachtsurplus.com/ Good luck.
G
Gary Bridi
question
Will a stern rail from a Cat. 25 fit a Hunter 23? thanks GB
Ron
been there, done that
Gentlemen, you are correct the H23 could use a stern rail, especially if you sail salt water or large lakes. (Great Lakes) I've researched this for two years, looked up articles in archives, some of my responses are still there. It depends on how much rail you really need. I don't believe a C 25 rail will fit. You could call (714) 642-6506 Railmakers and have one made. I recently purchase a pair or Capri 22 stern rails, $54 ea. one port one starboard, yes there is a difference in port and starboard angle of the decks I attached the existing life lines and made one for across the stern. These fit very well and required only a small modification in the angle of the forward bases. use a large hammer. works great. don't forget to use plenty of bedding and a backing plate. You could go to any Catilina dealer and see the rails of the Capri 22 they do work! while you are there pick up the Catilina 22 rudder washers very large aluminum washers and bolt assembly grind down the little nob on onw of the washers, they work well on the kick up rudder of the H 23 and are very easly to adjust tension on bolt. the one nut is really a handle. Good safe sailing Ron
