I need some help from a fellow 42 Passage owner please. The bolts that hold the stern rail on are missing on the starboard side. I have looked and am not sure how to access the inside in order to put the nuts on when I replace the bolts. The only option I have seen that might be possible is to cut a small access from the lazzerette. Is this the correct method?
Additionally I would like to add some solid supports to help stabilize the davits. (From the stern rail to the deck) Has anyone else done this and how did you do it?
