Stereo Radio not working
522
Jeanneau 389 Grosse Pointe Farms, MI
I traced the wires back and found the fuse block was heavily corroded.
The ground was not adequate.
I don't understand DC that well but I suspect that could cause the voltage drop.
New fuse block works wonders.
The other part I had to learn was the stereo has a ground (black), power (red), and 'always on' power for memory (yellow). I didn't realize you need to hook up both the red and the yellow. The red is operated by the breaker and the yellow is not (of course).
The Sony instructions was not that clear, but a coupld minutes on the phone with Craig was terrific.
Feb 6, 1998
11,716
I do have a multimeter and will try that.
The radio works (took it to West marine and they plugged it in).
Was just hard for me to believe that the wiring could go bad...
I will have to figure out which is are the two leads for power and ground (looks like black is ground and yellow is power)...
Should be:
Yellow = Power & Memory wire - Ideally connected to a non-switched 12V source
Red = Ignition - This is switched and turns the radio on/off
Black = Ground - Must be connected to battery neg or the neg DC bus
All of these three wires need to be used. Both yellow & red should have 12V DC in order for the radio to operate..
Jul 8, 2005
522
Your explanation is better than mine.
I meant to convey the same message.
Feb 6, 1998
11,716
Sorry I had not read the entire thread before posting, early trying to get to work etc.... Now I see you figured it out!!
