Steering Wheel
704
Catalina 30 Sidney B.C.
I have a 300 inch wheel on my Catalina 30 and want to go smaller to make it easier to get around the wheel , any thoughts?
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Wow, you have a big wheel I didn't know they got that big.
I just have a little tiller.
Ken
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
Edson also makes a device to allow you to remove your wheel and attach it somewhere else.
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
A quick calculation says that a 300" wheel would have a diameter of nearly 8'. I doubt it is 300" in circumference.
I know that Catalina 30's are beamy but that is ridiculous.
Aug 26, 2007
284
Hunter 41DS Ventura, California
Wheel
I put a Lewmar folding wheel (I think it was 36") on my Catalina 28. Worked great.
Jan 4, 2010
1,037
Farr 30 San Francisco
Smaller wheel = higher steering effort due to less leverage
Something to keep in mind. Effort should be proportional to the diameter.
Apr 10, 2008
47
Catalina 30 Detroit
It won't be much easier to get around a smaller wheel, and you'll regret it when sailing. Go with the folding wheel or the quick release if you must.
You'll still have to step up to get around the smaller fixed wheel.
Joe
Jun 1, 2004
8,349
You can purchase any size you want. There are plenty of resources online to find the one you want..... buy one and see how you like it. Or..... you could mock one up with cardboard or plywood and try it. (not under way, of course) In the end, it is you that will make the decision.... so don't be afraid to experiment and evaluate the changes objectively.... so you can go back to the original set up. Don't throw the old wheel away, btw.
When you say "easier to get around the wheel".... in what circumstance is the hindrance most annoying? Is it for crew movement, for the driver going over to adjust something, etc.? There may be other ergonomic or procedural changes that might make your cockpit mobility less critical to happy sailing.... moving the winches, for example, or your steering position (move to the side or sit in front, perhaps)
Jul 8, 2011
704
Thanks all I think I will stay with the 30 inch diameter wheel and get a quick release for it
Lost, save yourself some BIG $$$. Just grease the nut that's there, it'll come off whenever you want. Saves about $100!!!
