Steering wheel shaft Beneteau 393
Jan 20, 2023
4
Beneteau Oceanis Clipper 393 Trondheim
Hello,
I am thinking of upgrading my steering wheel to a Lewmar Folding Wheel.
Before I order, I need to know if the shaft in my 393 (2003 model) is a 1" Morse Taper Shaft or a 1" Parallel Shaft. Any of you know?
I also need to choose 40" vs 42" diameter. I think I'll go for 40", but any advice in this matter is also appreciated.
Thank you.
Measure the wheel you have and use that size.
The clever people at Lewmar have a solution to your question. The wheel comes with a removable insert for the hub. When I got my wheel last summer it came with 2 hubs, a tapered hub and a straight hub.
When you pull the wheel off, you will be able to tell if you have a tapered or straight shaft. If you are unsure, take off the wheel turn it around and see if it goes back on. If it does, you have a straight shaft, if not, it is tapered.
