Ryan Ericson
Hello all,I completed the second step of buying a 1977 C30, the sea trail. The wind was calm - 5 knots plus or minus. The boat was very hard to keep on a straigth course. Is this a known problem for the boat? I tried to use the autohelm 3000 and the autopilot had the same problem. Under power the autohelm worked fine the boat when the boatwas at crusing speed, 5.5 knots with the yanmar 12. The boat did pull to the right, I would assume from the rotation of the prop. Is there a problem with the rudder or is there a fix?Thank you for your time
