Russ Smith
Hi EveryoneI've got a 1979 Catalina 30 with a 5'3" draft. It has wheel steering (which I'm certain they all do), which has become a little stiff in the last couple of months.I disconnected the wheel steering from the rudder, and found that the rudder is still very free moving, so I'm certain that the stiffness is in the steering linkage. The pedestal that I have has gear sprocket behind the wheel connected via bicycle chain to another sprocket under the cockpit floor, then connects via a shaft to what I suspect is a rack and pinion to a push/pull rod that attaches to a bell crank on the rudder.There is grease in the fitting top and bottom, which appear to getting a little dry. But, there are no fittings to service the grease.So, my questions, am I going to need to disassemble the entire steering system in order to grease it? And, does anyone know the name of the manufacturer of the steering pedestal.Russ
