Just Lean Over!!!
Just lean over and and stear the engine with by hand.For the most part, I try to leave the outboard in a forward position, but in tight spaces there is no other way but to turn it by hand.The way I see it, outboards can be more or less manueuverable than inboards, depending on how you use them. If you turn your outbaord, you will get direct thrust to stear you in the direction you want to go, but if you leave it in the straight ahead position, you have to wait until the boat has enough forward momentum for the rudder to be effective.With an inboard, you have the advantage of not having to lean over an turn the engine, but remember!!! the prop is right in front of the rudder. The prop will direct its thrust straight back, but the rudder will deflect it to stear the boat in the direction you want to go. You don not get this with an outboard, which is why you have to steer the engine.With regard to a linkage between the rudder and the engine... I raise my engine once I am finished using it to reduce drag. I would imagine that you would have to disconnect the linkage once you are ready to raise the engine.Again, I only use turn the engine when I am getting in and out of the slip. Since I have no experience with a linkage system, I can only speculate that I would rather reach over the back of the boat to turn the engine, rather than to hook and unhook the linkage system. Yes, the linkage system sounds neat, but it also sounds like it would be more trouble than it would be worth.Sincerely,Michael Gordonmichael@chocolatetruffles.com
