Ron Brassord
I had sloppy steering on my newly acquired C30, and took up the deck plate behind the pedestal and found the wires were a little loose. I tightened them quite tight, and the boat performs much better as does the Autohelm 4000. I just read that there should be some play in the cables? Any opinions? I found the system was loaded with dirt and corrosion, and dry of grease. I cleaned up the area, and slathered on grease. I flushed the compartment and saw the drain directed the water to the bilge. Should it have gone overboard? I wanted to service the top end of the pedestal, but can't figure out how to remove the compass. I started removing the small screws in the top ring, but quickly stopped when I saw an air bubble rise. Later this disappeared, but where? I don't see any other fastenings that could hold the compass base in place. It has to be removable, but how, without breaking something? I hope to oil the chain, and lube the control cable ends. Any help will be appreciated. I have stripped down all the oiled interior wood, and have 2 or 3 coats of varnish on with spectacular results. The interior of this boat is excellent quality. Good sailing Ron B Lighthouse Point Fl.
