Year of manufacture wouldn't have anything to do with it, the steaming light has been required for about 150 years. (We're not still using steam, right? That's how old it is.) As was previously posted, the mast top anchor light will meet the requirement, as long as the stern light does not come on with it. Power driven vessels under 12 meters in length are allowed to combine the stern light and masthead (steaming) light in one unit. Think outboard runabout with the white light on a pole. The only problem is on a sailboat that puts the stern light way up in the sky where it might not be seen from up close. You would show the red/green side lights and stern light when sailing (engine not running), red/green side lights and anchor light when motoring with or without sails up, and anchor light alone when anchored. You need all three lights on separate switches to make this work.
If you opt to add a dedicated steaming light, more that it does not have to be half way up the mast where you usually see them. Only needs to be one meter higher than the side lights. On one of my boats I put it about five feet above deck. That way when it went out I could fix it without climbing the mast. You could even install it there without taking the mast down.
