Static Electricity
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
Any solution to the static electricity I generate everytime I take my sail cover on or off?
That has never happened to me but my first thought is maybe your rig is electrically isolated from the water. A grounding strap from your mast to someplace that is grounded might help.
Jul 7, 2004
8,534
Hunter 30T Cheney, KS
Our club had to put dissipaters on our weather station to bleed off the buildup from the wind. Not sure how this helps but I think your problem has to do with dry, windy conditions. Maybe clip a wire to your cover and toss the other end into the water?
May 24, 2004
7,213
CC 30 South Florida
The static buildup occurs as a result of frictional contact between the sail material and the sail cover material. Try to minimize friction by tying bungees around the sail cover to reduce wind induced movement. There is also the possibility that you could be building up static charge; the way you walk and the material of your shoes could be doing it. Don't slide your feet especially if you have carpet in your boat cabin.
Johnb
Hunter 37-cutter Richmond CA
When I used to sail on inland Lake Don Pedro in the summer time the whole main and jib would build up a static charge. The hair on your arms and head would stand up and sooner or later during sail handling, especially after sailing, you would get zapped. Dissipating that charge requires that the whole piece of material be made conductive. Try to learn to enjoy it.:biggrin:
On a more serious note this is a good reason to be careful how you handling gasoline.
2,405
Hunter 30 Everett, WA
That's why misting with water works. At least it works for other things.
Ken
Mar 26, 2011
3,961
Corsair F-24 MK I Deale, MD
A big difference re. salt water. I thought the initial post was a joke.
I bet washing the cover with fabric softener would work (it is conductive--that is why it works with clothes).
Db421
Jun 7, 2004
95
Hunter 34 1986 Lake Lanier, GA
I've see a 1" arc between my hand and the cover a few times. I'm constantly getting zapped when putting up or tsking down the sail. Can't wait to solve this problem...
That sound awful. I can't help but imagine some interesting Pavlovian experiments we could devise for the unsuspecting sailor.... :yikes::cowbell:
Gee Bubba, everytime I try to get a beer out of the cooler zzaaaaap!
I think the fabric softener idea is not a bad one. Maybe you could make a dilute solution of fabric softener, put it in a garden sprayer and mist your sail and cover next time you raise the sail.
Alternatively a caribiner (sp?) clip on a length of chain might make a good ground for your rig. You could clip it to a shroud, drop it over the side before you touch the mast and maybe dissipate the charge.
Oct 24, 2010
2,405
Thinwater is right. Fabric softener will work, as will any wetting agent (soap or detergent) If it happens regularly I think the fabric softener makes sense but something more permanent may make more sense (Sorry, I don't know what that would be.)
Ken
